Hi,
I was hoping someone can give a practical advise and insight. A month ago my car's steering fluid level fell below the "low" mark on the steering fluid dipstick ( I heard a whirring sound which prompted me to check the fluid level). I filled up with "Esso Type F (non dexron / non mercon) ATF" to refill it. Now suddenly, it has started happening daily. I hear a whirring noise from the steering so I check quickly and find that the fluid is below low. I just refill it with the same bottle. Can you please advise on:
1 What part is likely failing?
2 What could have I done to prevent or defer the failure?
3 What are my options to resolve the situation?
4 Is this a frequent problem on high mileage cars?
I have 315,000km on the car (~198,000miles). It is an automatic and it is all stock. All parts are fractory original except the radiator and the turbo and other minor wear and tear stuff.
Thank you very much.
Daily Steering Fluid Loss, '98 S70 T5
chuckcintron
- Year and Model:
If you are not seeing any obvious leaks (i.e. from any of the hydraulic line connections), then take a close look at the inner tie rod boots. If you can remove one end of the boot (preferably the inside end), see if your power steering fluid is leaking into the boots.
If so, your steering rack needs to be replaced.
-Chuck
-Chuck
1997 855GLT
pfeener
- Year and Model:
- Been thanked: 2 times
To start with the PS fluid type for your car is Dextron III. I don't know what, if any, effect the type F would have. If your adding every day, it's going somewhere. Climb under there and see where it's leaking.
Hi,pfeener wrote:To start with the PS fluid type for your car is Dextron III. I don't know what, if any, effect the type F would have. If your adding every day, it's going somewhere. Climb under there and see where it's leaking.
The manual says ATF fluid. The indep volvo garage guy said either dexron or non-dexron type ATF is good. I had to make a decision on the road so I went with what seemed to be closest to reg. ATF. I will check under the car and post back soon.
Thank you.
98 S70 T5 Auto
03 540i 6sp
03 540i 6sp
In case for someone who needs this information in the future: The part # according to a Canadian Volvo Dealer (Brossard, QC) isGhassan wrote:Hi,pfeener wrote:To start with the PS fluid type for your car is Dextron III. I don't know what, if any, effect the type F would have. If your adding every day, it's going somewhere. Climb under there and see where it's leaking.
Thank you.
Volvo part #: 8251305
price; $746.98 (Cdn) with core exchange.
Thanks.
98 S70 T5 Auto
03 540i 6sp
03 540i 6sp
- 1290 Views
- 1900 Views
Last post by RickHaleParker
- 17 Replies
- 2146 Views
Last post by CIK7
- 11 Replies
- 3158 Views
Last post by Chuck W
- 26 Replies
- 4073 Views
Last post by WGFP
