Need help...anyone have a master window switch pull?
- Has thanked: 17 times
- Been thanked: 35 times
This is for a S70. As the title says, I need the plastic "pull" (I call it that because I don't know what to call it) for the master window switch. Actually, the driver's would be nice, but I know that any of the window "pulls" will work...just the inscription for the master says "auto" on it. I let my wife drive my S70 the other day and she evidently yanked up on it too hard and pulled it off. It is suppose to be attached to the pin that goes through a metal hole in the master switch itself but whatever attaches it broke off. If someone has one of these laying around, I will be glad to pay a fair price and shipping for it. The plastic "pull" piece along with the attached pin would be nice, but I think I could get just the plastic "pull cover" to work if someone has one of these. The master switch is fine. I have to sort of hold down the base of it as I pull up on the little skeleton piece and do the same as I push down and the window works flawlessly. It just looks bad and I'm afraid I'm eventually going to break the whole thing unless either exchanged or the pull cap replaced.
JFO
- Year and Model: '98 S70 GLT
MIJ,
I replaced my switch recently and I can probably send you the piece you need. I'm not at home and won't be able to do this for about 3 weeks however. If you don't find one by then, I'll send it to you.
Jim
Jim
'98 S70 Turbo GLT
280,000 km
280,000 km
If you can't find one i'll give you the number to B & F auto in Chattanooga
they have everything, (salvage yard, where i bought both my 850's and
my s70)
my s70)
Previous 93 850 GLT, 95 850 GLT, Current 1998 S70 2.3 LPT 17inch Sport E3, K&N, PBR Deluxe, Cross Drilled F&R. Bilstien touring. Wishlist ECU upgrade, Strut brace, etc.
Thanks bhales...JRL is sending me a used (broken) one...I think I can cull the part off of it that I need. If that doesn't work, I'll probably buy JRL's good one from him. Actually, I already promised him that I would.
- 1717 Views
- 1465 Views
Last post by beigg
- 18 Replies
- 3793 Views
Last post by FLXC90
- 2459 Views
Last post by halseyfolk
- 1021 Views
Last post by wizechatmgr
