Daytime Running Lights, 02 V70XC
FritzMissel
- Year and Model:
Does anyone know of a way to turn off the daytime running lights on the v70xc? I assume the instrument panel lights are on the entire time and I'm afraid I'm going to be replacing bulbs too frequently. The manual says take the car to the dealer if you don't want them on...is there another way? Thanks!
If you do not want the panel lights on set the light switch to day position. The day position does two things a. turns off the panel lights and b. cuts out the bright lights holding relay. A second way to turn off the panel iights is to turn down the illumination thumb wheel.
Current Stable.
99 V70 XC
95 850T
91 240
Previous
76 242 Stick
76 245 Stick
78 244 Stick
83 760 Auto
85 240 W Stick
87 240 Stick
99 V70 XC
95 850T
91 240
Previous
76 242 Stick
76 245 Stick
78 244 Stick
83 760 Auto
85 240 W Stick
87 240 Stick
JRL
- Year and Model: Several
- Been thanked: 16 times
That won't help the obvious problem, ALL the other lighs are on, the taillights, marker lights et al.klojbg wrote:If you do not want the panel lights on set the light switch to day position. The day position does two things a. turns off the panel lights and b. cuts out the bright lights holding relay. A second way to turn off the panel iights is to turn down the illumination thumb wheel.
DRL's should be a lower wattage light in the front only, like ALL OTHER CARS HAVE
JRL
Absolutely nothing to be sorry about, just take it to a dealer and work out a fair price.klojbg wrote:OOPs SOREE
There are no downloads involved just 5 minutes of computer time and you should NOT be charged more than 50 bucks
- 2357 Views
Last post by Liliflower
- 867 Views
Last post by Snaab
- 3499 Views
Last post by BEJinFbk
- 11 Replies
- 3028 Views
Last post by Faust
- 1289 Views
Last post by 93SCMax
