Just replaced PNP, did not fix my issue. Need to replace the Torque Converter Lockup Solenoid next...
Instructions on how to would be appreciate, but more important, where to get the part?
Thank you all... =(
Need to replace Torque Converter Lockup Solenoid
- Year and Model: Many Volvos
- Been thanked: 76 times
The only place I have been able to locate them is from a dealer. FCP can likely get you one as well. My guess is that it will be special order and they won't have it in stock. Most dealers seem to be able to get special order stuff within 48 hours.Instructions on how to would be appreciate, but more important, where to get the part?
VADIS has some very good exploded drawings of the transmission control system but I don't have it with me at the moment.
phly50
- Year and Model: S70 1998
Check this link for some information on the tranny. Cheers, Phil
http://www.babcox.com/editorial/ic/ic40238.htm
phoenix_iii
- Year and Model:
I guess that's where I read S1 and S2. What do I ask for from the dealer? What's the proper phrasing to get 'industry' (mechanics) discount?
1995 Volvo 850 Turbo
phoenix_iii
- Year and Model:
what do I want to ask the dealer for? I have an image from a shop manual that shows S1 and S2 on the outside of the transmission, I think. With a lift, my mechanic shouldn't have a problem replacing it right? Anyone remember the price for the S1 and S2 solenoids? I want to order them asap! =)
p3
(I accidently cleared the code(s) in A1 and A2 when I got the car. Just did the other modules and nothing related to my problem found (cleared all codes) =)
p3
- Has thanked: 17 times
- Been thanked: 35 times
Just ask the dealer for the S1 and S2 solenoids for your particular transmission....yes, you can change them if you lift the engine/tranny slightly (under oil pan with a 2X4 if I recall) and/or slightly drop the subframe... .but others might chime in w/ better advise as I actually haven't done this particular r&r.
You do realize that S-1 and S-2 have nothing to do with the torque converter lockup function don't you? That is its own solenoid that is often called S-L.
What are your symptoms?
phoenix_iii
- Year and Model:
Ozark
No codes returned in A1 or A2, and that includes the trip down the street to get my emissions sticker (passed!). I cleared the A1 and A2 codes and put at least 15 miles on it and nothing came back. Do I need the SL solenoid instead of S1 and S2, SL = Torque Converter Lockup...
My symptoms were/still are
1) Car starts in too a high a gear (feels like 3rd).
2) Put the accelerator down, it will downshift to first where it belongs, and then un-gracefully enter second...
When coming to a stop, it will more often than most STAY in too high a gear, and get down around 500rpm (danger of stalling out) and fall into first finally, or has, on occasion, stalled out. Fluid is good.
Thank you for asking the hard questions.
You sure that your PnP switch is adjusted properly? May be as simple as that.
phoenix_iii
- Year and Model:
No, I don't. I'm trusting the mechanic who did the install. I see it was scored (I saw it part way installed) so they probably didn't have the alignment tool... I also printed out the Bay13 instructions for them as well...MadeInJapan wrote:You sure that your PnP switch is adjusted properly? May be as simple as that.
How would one adjust it? Also, if it is out of adjustment, would it cause the problem described? =(
- 1043 Views
Last post by warmblood58
- 1404 Views
Last post by atomicthumbs
- 944 Views
- 4936 Views
Last post by MadeInJapan
- 483 Views
Last post by rhalkyard
