Service engine light, 98 v-70, allwhle, w/turbo
The instructions are there: http://volvospeed.com/850slight.php
It's easy enough that I could do it myself, the first time around.
However, I drive a Volvo 1995 850 Wagon. Should be similar for you. Volvo experts with more expertise than myself may want to weigh in on this.
Cheers!
Cheers!
I may be wrong, but I'm pretty sure a 98 will be different. It will have the OBDII connection instead of what the early 850's have. I know my 97 has OBDII and I can't reset my light without the proper tool. I have an OBDII reader, but it won't reset the service light.
Larry
Li'l Red Wagon
97 855 GLT
Li'l Red Wagon
97 855 GLT
- billofdurham
- Year and Model: 855, 1995
- Been thanked: 5 times
My book says -
Press and hold the trip reset button.
Switch ignition On.
Keep the trip reset button depressed until the service indicator light starts to flash (approx 10 seconds).
Release the trip reset button within 4 seconds of the light flashing.
Bill.
Switch ignition On.
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
Previously:
- Has thanked: 17 times
- Been thanked: 35 times
Sorry Bill....that works on '99 and '00's but not on '98's.
He'll have to use a special reset tool.
I bought mine on eBay....made by DRAPER.
Look for DRAPER Volvo Reset tool....it wasn't much more than $50 or so.
These DRAPERS are all sent from the U.K.
I beg to differ with you....either the Volvo reset tool or one like I have. I have successfully turned off my light with the Draper every time. I understand that there are at least 2 others out there that will do this (made specifically for this reason), but code readers will not do it, and you're right in regards to, if you don't have one of these specific tools then the Volvo reset tool is your only other choice.JRL wrote:98's need the Volvo reset tool, sorry
JRL
- Year and Model: Several
- Been thanked: 16 times
You're not disagreing, I said the same thing except you just added another tool.MadeInJapan wrote:I beg to differ with you....either the Volvo reset tool or one like I have. I have successfully turned off my light with the Draper every time. I understand that there are at least 2 others out there that will do this (made specifically for this reason), but code readers will not do it, and you're right in regards to, if you don't have one of these specific tools then the Volvo reset tool is your only other choice.JRL wrote:98's need the Volvo reset tool, sorry
Bottom line is he STILL needs a tool to do it
- 2313 Views
Last post by oragex
- 25 Replies
- 18601 Views
Last post by ADriggs26
- 4193 Views
Last post by earthworm
- 1944 Views
Last post by psamanni
- 27 Replies
- 4148 Views
Last post by bmdubya1198
