1999 S70 T5 P0137 o2 sensor circuit low volts
Spark Plug Wars - What's Best for Your Volvo
As title says, i have a 1999 S70 T5 with a check engine light on with a P0137 "O2 sensor circuit low volts" (bank 1 sensor 2) code set. Does this mean I need to replace an o2 sensor? Which one would be bank 1 sensor 2? Thanks.
- Year and Model: Many Volvos
- Been thanked: 76 times
Bank 1 - Sensor 2 is the rear sensor but it may or may not be the sensor itself. I would start by cleaning the MAF sensor, particularly if you have a K&N air filter. To clean the MAF use either electrical contact cleaner or MAF cleaner. Spray it and let it dry. Don't scrub it or even touch it.
- Has thanked: 17 times
- Been thanked: 35 times
I agree with Lee, but usually when a rear sensor code shows, it really is the rear sensor. However, my experience has been that when the front sensor code shows, it usually isn't the sensor (although it could be) but vacuum hoses or the MAF sensor.
ummmm, probably so. Upstream would be the front one, I would think.
- 875 Views
Last post by Gobblin81
- 772 Views
Last post by RobsS40
- 948 Views
Last post by Randall0208
- 2266 Views
- 548 Views
Last post by mar601
