new fuel pump,new relay,different computer,same problem,
the car will start if the fuel pump comes on when the ignition is turned on.
if the pump does not come on turning the switch off then on again brings the pump on.
intermittent no start 92 940
Volvo Air Conditioning Problems & Fixes
wojeepster
- Year and Model:
Sounds like the electrical part of the ignition switch has gone bad. you can get one at www.fpcgroton.com
outofworkjoe
- Year and Model:
Try this replace your powerstage this sents power to the coil,these overheat and die.Sometimes your will run,but after warming up it dies.This powerstage is mounted on the inside finder.Find these at your junk yard.
1991 volvo 240 207000 my car/1993 volvo 940 turbo 160000 wife/1989 245 267000 sons
- 1703 Views
Last post by manovlov
- 2254 Views
Last post by KevinWeaver
- 1037 Views
Last post by vtl
- 499 Views
Last post by KirstenGK
- 5038 Views
Last post by DaveOdie
