A few days ago my car gets hot i check the coolant level but it was perfect a friend tool me it could be the water pump but i dont have any idea...
What i can do to find the reason or fix the problem????
850 95 Getting HOT!!!!!!
Does it overheat idling, around town, on the freeway, or all of these? When it gets warmed up feel the temperature difference between the upper and lower radiator hoses, if they are not both hot the thermostat is bad. Water pump is unlikely if it's not leaking.
95 850 turbo
- Has thanked: 17 times
- Been thanked: 35 times
If you're saying the needle on the dash goes up past the halfway mark, then it's almost always a bad thermostat.
- 24 Replies
- 1260 Views
Last post by TisMe
- 770 Views
Last post by JerryKirkpatrick
- 250 Views
- 968 Views
Last post by FMradio
- 17 Replies
- 4345 Views
Last post by villagepc
