OBDii diagnostics on laptop
asummers
Year and Model: many
Post by asummers »
Has anyone used any of the cables and programs that are available for your laptop to be able to read diagnostics on a laptop computer?
Arbelac
Post by Arbelac »
Yup. Is there a specific question you had?
-1998 V70 Cross Country Wagon, B5254T, AWD, 231000KM
- 2001 V70 T5M, FWD, 205000KM, QBM Strut Brace Conversion, QBM Poly Lower Transmission Mount, HD Endlinks
asummers
Post by asummers »
Would you recommend the one you have used to someone else? If so, what brand is it and where did you find it? I have seen some online with the cable and software, but aren't sure if they are worth buying or not.
Arbelac
Post by Arbelac »
Anything based on the ELM chips should be fine. I've got one from OBD2AllInOne.com that works great.
Check Scantool.net as well. CHECK to make sure your computer/laptop has a serial port, else make sure you order the USB model.
There's a fair bit of software floating around, I usually just use the free Scantool.net software for reading codes.
Has thanked: 17 times
Been thanked: 35 times
Post by MadeInJapan »
People are having very good luck with the VOL-FCR Software. Do a google and you'll find plenty. Mine is on its way so I can post more once I have a chance to try it. Btw, this is suppose to reset the service light on the '96-'98 FWD Volvo's as well as query the SRS and ECC modules and reset their fault codes- something not possible up until now without Volvo's specific and expensive scan instruments.
Nick'sTurbowagon
Post by Nick'sTurbowagon »
Have you gotten your copy of this software?
Does its show/clear P codes ie for SRS system?
Does it clear service light?
How is it?
Is it worth buying?
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2656 times
Been thanked: 1248 times
Post by matthew1 »
Looks like it's around $200 US.
http://kontakt.s-tech.pl/index.php?go=s ... setlang=en has a few screenshots. Code software either works or it doesn't, and none of it is pretty. :)
Also -> Amazon link
Year and Model: Many Volvos
Been thanked: 75 times
Post by Ozark Lee »
I did.
Yes - I messed up and didn't hook the airbag on the steering wheel back up - it cleared the code fine and didn't come back.
Yes - that is one of the main page buttons on the menu. I just wish it had a function where it would send 1200 Volts to the lamp to terminate it forever.
How is it?
It doesn't read engine codes but it is a great companion to a generic OBD-II scanner.
Is it worth buying?
I would say yes but I have three 850's in the driveway at the moment.
tjts1
Year and Model: 96 855 NA 5 speed
Been thanked: 4 times
Post by tjts1 »
http://torrent-finder.com/vol-fcr,torrent,search.html
You can get the cable off Ebay for $20.
mtagoon
Post by mtagoon »
Perfect Set!
For : 850 >96, S/V 70[97-98], C 70[97-98], 940/960 >96, S/V 90 and S/V 40[97-98]
Hardware : http://www.planetfall.com/~jeff/obdii/
Software : http://www.ilexa.co.uk/content/category/2/2/19
Cable : http://www.scantool.net/products/produc ... ucts_id=22
[12.95 US$]
Ex. : http://www.volvoclubthailand.com/cgi-bi ... 1213444337
