PNP switch
ooops its a 1992 960 Also, could I undo the transmission fluid line and put on clear tube and put end in transmission fluid see if it is sucking fluid then determin if it is the transmission pump, or could that possible be a sylinoid too?
- billofdurham
- Year and Model: 855, 1995
- Been thanked: 5 times
Wow - three for the price of one!!
It is highly probable that it is the PNP switch causing the lack of lights if you have checked that the reverse light bulbs are not blown.
Try moving the shift lever from 'P' to '1' and back 15 to 20 times. This has been known to clean the PNP switch contacts. If that fails then it may be time to invest in a new switch.
The PNP switch is mounted alongside the gear shift lever.
Why do you want to see if it is "sucking fluid"?
Bill.
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
Previously:
I recently had my car plugged up and found out that not only was my air pump bad, but it is showing to replace the PNP switch. How effective is cleaning the contacts by moving it back and forth? Will it just do the same thing in a week if it is not replaced?
1998 s70 GLT 130Kish
- 11 Replies
- 11495 Views
- 806 Views
Last post by polskamafia mjl
- 1138 Views
Last post by techedbob
- 1334 Views
Last post by 93Regina
- 1172 Views
Last post by jforce
