I've read on-line about people saying that if the angle gear is so much of a problem, just disconnect the drive shaft to the rear wheels and make the 2000 XC-SE a FWD car. Sounds good to me. I can live without another $3000 repair bill.
BUT, I haven't actually read of anyone doing this, and if so, did it work out okay. I asked one of the mechanics at my Volvo dealership about this and he said, "Oh no, that would make the code lights go off".???? I can put some electrician tape over any lights on my dash.
Stories of success with this procedure, and pictures of how to disengage the AWD would be appreciated. I'm ready to do surgery to my car and make it the reliable Volvo it was intended to be.
Thanks in advance.
Greybeard
2000 XC-SE Disconnect AWD and make it FWD
Greybeard
- Year and Model: XC-SE 2000
Greybeard
2000 XC-SE
2002 Camarao Z28
2009 VW New Beetle
2009 Dodge Ram 1500
2011 Honda Accord SE
2001 Harley Davidson Electraglide
1999 Harley Davidson Sportster 1200 Custom
2008 Suzuki Four Wheeler
2000 XC-SE
2002 Camarao Z28
2009 VW New Beetle
2009 Dodge Ram 1500
JRL
- Year and Model: Several
- Been thanked: 16 times
No big deal, just remove the driveshaft
(WHAT CODE)?
(WHAT CODE)?
johnnyturbo
- Year and Model:
I've done it and it doesn't do anything but make the mpg go up a bit, and then cause your fronts to spin where they hadn't before..starting off on wet etc. Do you have a problem or is it just preventative maintenance? BTW, no codes will go off...most the time Volvo techs have their heads so far up their exhaust pipe they are only trying to get money per dealer order.
1998 V70 XC 120k miles
1995 BMW 520i 136k km
now sold-
1995 BMW 540i lovely fast
1979 MBZ 300D 4 door slow/steady
1964 Buick Skylark 2 door (no post) damn drunk drivers
1963 Chevy Impala 2 door "hardtop convertible"dad bought new
now sold-
Kansas Jayhawk
- Year and Model:
My son's 99' S70 AWD turbo was making a loud noise under the car towards the front part of the drive shaft. I had it checked out at the Volvo dealer and they said the front U joint or bearing was making the noise and it is $1200 for a whole new drive shaft. I asked if they could take the drive shaft off and they didn't know so they checked with Volvo factory and they said it could be removed and so the dealer removed it and no codes will show up which they haven't. I took the front bearing apart and it is dry and what grease there was was hard and dry. I am in the process of replacing the front bearing now and will reinstall the drive shaft. However, it has snowed and iced three times in the 3 weeks we have had the shaft off and it would be good for that type of driving. If it can't be repaired the S70 will probably be a front wheel drive.
JRL
If it's JUST the front, that CAN be replaced and you should be fine
- 11 Replies
- 15923 Views
Last post by June
- 1620 Views
Last post by foggydogg
- 2021 Views
Last post by Lelica
- 2538 Views
Last post by RickHaleParker
- 815 Views
Last post by BEJinFbk
