CV boot replacement
I need to replace both outer CV boots on my 96 850 wagon. I ordered the parts from FCP, I was wondering if anyone has done these. My guess is that I will need to pull the axle shafts as it doesn't look like these are the wrap type of boots.
2004 XC70
2005 S60 2.5T AWD (gone)
1996 850 GLT Wagon in Blue (gone)
1996 850 GLT Wagon in Green (gone)
- billofdurham
- Year and Model: 855, 1995
- Been thanked: 5 times
Drive shafts have to be removed.
Full details are in the manual pinned at the top of the forum in the .pdf file 'axle shafts front'.
Bill.
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
Previously:
Thanks, I ended up deciding to replace the shafts all together. With 152,000 miles they are probably close to due anyway. I got them from FCP for $75 each which is a fair price for sure.
2004 XC70
- Tsquared
- Year and Model: 11 C30
- Has thanked: 1 time
Tim, good choice. I found the boot repair kit to be almost as expensive as a new shaft.
'11 C30 T5
'96 854 - died an early death with 184K miles. Killed by the front end of an LTD on a suicide mission (T-boned and both cars totaled).
Got the axles and put them in. Very easy job. The axles were chinese (as expected for $75/each) and you could tell by the low quality steel. Don't know how long they will last but we'll see.
2004 XC70
tailor
- Year and Model: 2004 XC90 2.5T AWD
- Been thanked: 2 times
turbotim2 Posted: Wed Dec 26, 2007 4:04 am Post subject:
1)the new axels do they have the very big nuts like this : Wahn
The nut on the left is from a Wahn axel, I think 36mm
the nut on the right is from FEQ and has three stakes in in it (indentations)and is 22mm.
If they where FEQ with three stakes in them, did you just torgue them to spec, and in doing so ruin the thread along the way.
The oem nuts have to be staked after they are torgued unless they are the new bigger self locking type
2)I would think that you replaced with new nuts as indicated in the pdf:axel shafts front of 850 manual
a)supension arm to ball joint
b)supsension arm to anti roll bar arm
Am I correct or did you not deem it neccessary.
3)Should I expect to encounter a fair amount of foul language.
Tailor
1994 850 Auto Turbo wagon 306000km (Sold)
2004 XC90 AWD 188000km
"Life is like a reel to reel tape recorder,
the closer you get to the end,
the faster it spins."
Abe Gottschalk
Abe Gottschalk
The new axles came with new nuts. The nuts take a 36mm socket to remove and install but I believe the shaft itself is 22mm. Therefore it would be technically called a 22mm nut. Your picture didn't come through so I don't know what it is. I torqued the nuts on and called it good. I didn't use the manual you speak of. I am not sure on your last question, are you asking if I replaced the nuts on the hardware? If so, no I reused all of the bolts. They should be fine unless you see one is damaged or rusted beyond use. Also, you don't need to do anything with the anti-roll bar arm to do this proceedure. Foul language always adds to the experience, so I would suggest a sprinkling to taste.
The left side axle comes out with some force so be prepared to put a good pry bar on it. As long as everything comes apart as it should, this job should not take more then 2 hours to complete both sides.
2004 XC70
tailor
Yes thats what I meant.are you asking if I replaced the nuts on the hardware? If so, no I reused all of the bolts
Ask and answered, thank you.
I will try to ensure that the cap on the" foul language shaker" will not fly off when I sprinkle to taste!
Tailor
Abe Gottschalk
Abe Gottschalk
As a side note, the axle bearing on the right side definitely needed to be replaced so I am glad I went ahead with the full axle replacement.
2004 XC70
As another side note, I would also recommend replacing the axle seals in the transmission while you have the axles out.
2004 XC70
- 11 Replies
- 5938 Views
Last post by default
- 920 Views
Last post by CThompson
- 760 Views
Last post by boneman131
- 1647 Views
Last post by rocketman4321
- 3130 Views
Last post by foggydogg
