Hi to all,
The outside door handle of the front passanger side does not open the door. However, I can open the door from the inside and unlock it. Also, the outside door handle does move when it is pulled. The problems seems to be that it does not engage. Does anybody have any suggestions on what to look for when trying to fix this problem (i.e. name, location, and cost of broken piece)? Thank you for help and any information will be appreciated.
Outside Door handle problem, 1998, S70
- Has thanked: 17 times
- Been thanked: 35 times
probably disconnected inside. You'll have to take the inside door panel off to see.
It may be that you need a new lock module. I am having a similar problem and everyone is telling me the same thing.
http://www.volvoforums.com/m_85709/tm.htm
1998 s70 GLT 130Kish
zenmervolt
- Year and Model:
No, that will not be the same cause as your problem.dkbmx wrote:It may be that you need a new lock module. I am having a similar problem and everyone is telling me the same thing.
The problem in this thread is most likely a single broken mechanical connection in the latch mechanism. It's not related to the lock module at all.
'98 Volvo S70 T5 SE
'86 Porsche 951
'76 Porsche 914
'86 Porsche 951
'76 Porsche 914
bobsnow100
- Year and Model:
Yes,you will need to remove the interior door panel. Usually there are a few different metal rods that pivot when you pull the handle. Once you have the panel off,window in the up position, have someone pull the outside lever and with a flashlight, look inside at the mechanism to see if one of the rods is just off or if one is broken. Usually one of the ends is just pulled out of the plastic
- 735 Views
Last post by darrylrobert
- 1384 Views
Last post by Mauiman
- 1132 Views
Last post by Volvo S80
- 2023 Views
Last post by matthew1
- 1640 Views
Last post by Clemens
