Where does it connect? 1990 460
Rainbird
Post by Rainbird »
I've got a LH drive 460 with a carburettered B18K engine. On the bulkhead next to the cylindrical vapour separator is a large rubber grommet with a plastic cylindrical thing set in it. The grommet also takes the screen washer pipe through one side.
The only problem is that in an earlier photograph I have, this plastic cylindrical thing has a pipe on it which disappears off under the air filter casing toward the carb. Now, after having some work done on the motor this pipe is missing and there's no recollection of how it was plumbed in. The haynes guide refers to this item as a vacuum accumulator whilst The Volvo part description for this is a "cold start device", part number VO3446535.
Does anybody know where this thing connects on to the engine. I'm having hot running problems which I think are related to a vacuum leak and this missing pipe may be contributing.
many thanks
Peter
billofdurham
Year and Model: 855, 1995
Been thanked: 5 times
Post by billofdurham »
Take a good look at the carb and you should find a metal stub pipe with nothing attached to it. This is where the vacuum pipe goes. You may need to remove the air filter to get a better look.
I'm sorry I can't be more precise on the location of the stub pipe but my pictures don't actually show it.
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
Rainbird
Post by Rainbird »
Thanks, I'll give it a look
