I have a 2001 S40 1.9L Turbo, I've just gotton the fault code for the Oxygen Sensor Bank 1 (P0130 I think). Can you tell me if bank one is the sensor before the cat? I remember reading that this car can be picky about the O2 snesors (as far as manufacturer goes)...can you make recommendations? Should I go ahead and replace both sensors or just replace them as they start throwing faults?
Thanks
O2 Sensor, which is bank 1?
- Has thanked: 17 times
- Been thanked: 35 times
Bank 1 is the one before the CAT...the front one, but before you start throwing parts at this check all of your vacuum hoses. With the car idling, spray some carb cleaner around your hoses and see if your idle goes up. If it does, then you've spotted a leak. A lot of times the 02 sensor reads leaks and throws a code, so just because you've got a Bank-1 code doesn't necessarily mean your sensor is bad. If trying to find leaks doesn't work, also check other areas that would restrict air flow or open up air flow...turbo piping...even a dirty air filter. Hope this helps.
If you do find you have to buy an 02 sensor, what you need is the Bosch brand that is made for your car. www.fcpgroton.com (if not there, then their on-line parts store, www.foreigncarpartsonline.com or eeuroparts.com (free shipping on orders of $39 or more) and I've had good luck with http://www.autohausaz.com/ with O2 sensors (they often have them on sale).
Good luck and let us know what you find.
Check engine light on: ASE Master Tech - code P1132 indicates ' Front Heated Oxygen Sensor - Signal too high'
Bank 1 front O2 sensor did not switch for a predetermined period of time during oxygen sen monitor self test. Most likely solution replace oxygen sensor
also: ASE code P0014 'Exhaust camshaft position timing Over-Advanced (Bank 1)'
was confused words, ' Front / Before / Bank 1' (especially looking for parts/ordering descriptions)
Reading MadeinJapan Feb 4 2008 answered this question; Thank You
.....will check vacuum hoses with spray carb cleaner before ordering / replacing 02 sensor Front
is only Front-Before heated ? (4 wires) Rear-After non-heated ( 2 wires) ?
- 1841 Views
Last post by batman00024
- 14 Replies
- 12390 Views
Last post by pgill
- 1494 Views
Last post by hellarch
- 4737 Views
Last post by - Pete -
- 17738 Views
Last post by combatkarl
