2000 S70, light bulb behind engine temp/speedometer is out
brian_kearney410
- Year and Model:
I'm afraid to ask, but that's not the easiest to get to for replacement, is it?
- Has thanked: 17 times
- Been thanked: 35 times
The dash cover will have to come off in order to get to the instrument panel. Follow the following write up for the odometer gear to get the instrument panel out: https://www.matthewsvolvosite.com/odometer_fix.php
Then follow the information here about the actual bulbs you need to replace the burned out bulb. http://forums.swedespeed.com/zerothread?id=91687
Even though the 850 and S70 are a bit different, the basics are the same.
brian_kearney410
- Year and Model:
Thanks MIJ. Can you please confirm the 2nd URL in your post?
It's confirmed to work. Great write-up with pictures!
If you need further assistance, don't hesitate to post again.
MIJ
MIJ
brian_kearney410
- Year and Model:
Sorry MIJ, I meant the 2nd link is the same as the 1st. Shouldn't the second have been about bulb replacement?
Oops...you are absolutely correct. I've edited my post and changed the 2nd like to the originally intended link.
brian_kearney410
- Year and Model:
Hoping that someone can help me w/a quick answer. Called my local Volvo dealer to find out and purchase the bulbs for behind the dashboard. The service tech I spoke with "didn't know" what size bulbs, or even how many I would need. Does anyone know the size and quantity I'll need? Only want to remove the dash once! Thanks all...
Look in that second link or even better, look here for more info: https://www.matthewsvolvosite.com/forums ... highlight=
- 4164 Views
Last post by silentcircuit
- 1375 Views
Last post by FLXC90
- 1331 Views
Last post by richardgengle
- 2063 Views
Last post by misha
- 4896 Views
Last post by adrian22
