Engine Missing on Idle, 1998 S70 GLT
FritzMissel
- Year and Model:
My 98 S70 GLT has 180K well maintained miles and still runs smoothly...except when at idle, and then only when there is slight load on the engine (ie in drive, reverse, or with AC running). I've checked/replaced plugs, and checked over the vacuum hoses. I found two breaks in the hoses and fixed them...same problem is occurring. Any ideas? Thanks!
darrengbsn
- Year and Model:
I was having exactly the same problem you were (are). I checked vacuum hoses and changed plugs as you did - no help, I also replaced the MAF. Then I found that the 3-way hose which come directly out of the throttle body/intake manifold had rotted on the bottom - it was absolute luck that I found it. I was actually able even out the idle simply by crimping the hose with my hand, so I was pretty sure that I had found the culprit. Sure enough, after I replaced the hose my engine idles smoothly and my check engine light has not reappeared. Another member had the same problem and describes it better at:
https://www.matthewsvolvosite.com/chat/p ... hp?t=14353
here's a diagram: http://www.fcpgroton.com/product-exec/p ... ory_id/216
Good luck, Darren
1998 S70 GLT 130,000
Good luck, Darren
- 21 Replies
- 7163 Views
Last post by 800artfreed
- 11 Replies
- 4109 Views
Last post by straubman
- 1022 Views
Last post by ncomstock
- 344 Views
Last post by MoVolvos
- 1234 Views
Last post by obayha
