On the passenger side, a bolt snapped/broke away from the frame/cross-member, and the second had no nut
What I need to know is if there is an easier way to get in and replace the passenger side motor mount without having to remove the refrigeration unit, alternator and all the other stuff on that side?
What is the procedure to remove and replace the passenger side motor mount? And will we need to use the cherry-picker to pull up the entire engine or could it be jacked up enough to change it?
I sincerely appreciate any suggestions you may have to make this as painless as possible. Thanks!
