(click the image for the 'big picture' - this viewpoint is from above passenger side fender, up front -it's looking transverse across the car at the back of the radiator, the alternator is just visible in the lower left)
I have been thru the Haynes manual and cannot find anything about it. It is the fitting on the passenger side, back side of radiator, top -directly below large coolant hose. I believe it to be an oil cooler line (?)
Does anyone have prior experience with this - it is leaking enough to form drips and create a small "puddle" (2-3" dia) when parked.
I am theorizing this is the oil cooler inlet hose connection (I am unfamiliar with the fastening device - is there a special method to disconnection?)(BTW -there is an identical connection on the same side at the bottom of the radiator)
Any input will be helpful....
