1)Remove the switch/s using a very flat bladed screw driver.
2)Open the switch by gently prying at these points in the picture below.(4 in total)
3)The copper "rocker" will fall out do not loose it,note the orientation on the switch.
4)You will need bulbs, 12v 3.1X6.4mm W/wire from an electronics store. The amount will depend on how many you need to fix.
5)De-solder the old bulb and insert the new bulb and re-solder.
6)Before closing, test that the bulb works using a battery or cell phone charger and "jumper" the wires.
7)Put all the pieces in and slide the top down ensuring you do not unhinge the rocker.
8)Make sure you do not loose any of the "catches"when you close up the switch.
9)Re-install in vehicle.
