Hello,
Can anybody post a snap shot of the location of vacuum tree for seafoam access? Thanks.
I found it already
Did a seafoam thru one of the vacuum line with good results. Will do compression testing today.
You can go to this site for details of the "vacuum tower" http://volvospeed.com/Repair/vacuum_lines.php
When you remove the throttle body cover you will be able to see either 3 capped or 1 capped vacuum line. You can use either ones not being used (capped) to attach your suction tube. Please see uploaded image...
- 16 Replies
- 7034 Views
- 368 Views
Last post by CFL850T
- 233 Views
Last post by veezmachine
- 294 Views
- 11 Replies
- 2273 Views
Last post by dejongmc
