Let me start off by saying that you guys are awesome, without this sight many people including myself would be up a creek without a paddle. You guys have saved me gobs of money!
I had a question about my 95 850 n/a wagon w/ 142k miles vs. my 94 850 n/a sedan w/ 197k miles. The wagon idles at about 900-1000 RPM while the sedan idles at 400-500 RPM. At a 50mph cruise, the wagon is at 2000 rpm, the sedan is at 1400rpm. At a 70mph cruise the wagon is at 3000rpm, the sedan at 2500rpm.
Now, I know the throttle wire on my 90 740 can be adjusted by spinning the stop up or down, but the 850's throttle wire doesn't have that type of setup. Also, I am curious if the idle speed has anything to do with cruise speed as it seems to me in my limited auto knowledge that shift ratios/cruise rpms should be determined by the gearing and not the idler.
Finally, this may be attributed to a weight difference, but the sedan will blow the wagon off the road. The sedan just feels so much stronger off the line. I have a hard time believing that the wagon at 3342lbs can accelerate that much slower than the sedan at 3180lbs, a difference of 162lbs, or 1 avg adult.
My questions:
1. Is the difference in idle/cruise speeds causing the wagon to feel so sluggish?
2. Is the '95 wagon's idle/cruise speeds adjustable or will it make a difference?
3. Are there differences in the engines/transmissions from the '94 to the '95?
850 Idle/RPM question
- Year and Model: Many Volvos
- Been thanked: 76 times
Check the zero position of the tach. Chances are that they are not the same. After I fixed my odometer gear I failed to re-zero the tach when I put it back together.
Mine now idles at zero RPM and my speedometer is off by 3 mph.
One of these days I will pull it apart again and re-zero the gauges.
I had actually thought of that and they are both zeroed. Could they be geared slightly differently? Perhaps I should try cleaning a few components on the wagon, but where do I start in ways that might affect perfomance?Ozark Lee wrote:Check the zero position of the tach. Chances are that they are not the same. After I fixed my odometer gear I failed to re-zero the tach when I put it back together.
In my garage:
1990 740GLE Wagon w/ 252k miles
1994 850GLT Sedan w/ 197k miles
1995 850GLT Wagon w/ 142k miles
Parents:
1998 V70GLT w/ 132k miles
1999 S80 2.9 w/ 110k miles
Parents:
Volgrrr
- Year and Model: '95 T5 wagon
800 r.p.m. n/abnzlva wrote:Let me start off by saying that you guys are awesome, without this sight many people including myself would be up a creek without a paddle. You guys have saved me gobs of money!
My questions:
850 r.p.m turbo
There are only two types of car owners - those who own Volvos and those who wish they did.
Lee, after contemplating your comment, I returned to the sedan and looked at the tach. Sure enough you were right. The needle is well below the "0" mark. I thought I had zeroed it in the past, but perhaps I didn't do it correctly. Any chance you could point me in the right direction in zeroing it?Ozark Lee wrote:Check the zero position of the tach. Chances are that they are not the same. After I fixed my odometer gear I failed to re-zero the tach when I put it back together.
In my garage:
Parents:
Parents:
The procedure is the same as the odometer gear repair except that you don't fix the gear.
https://www.matthewsvolvosite.com/odometer_fix.php
The trick is to get the indicator needles to line up on their respective zero positions as you put the face of the cluster back together.
- 3783 Views
- 964 Views
Last post by arvik
- 495 Views
Last post by Jonboy74
- 20 Replies
- 6071 Views
Last post by bmdubya1198
- 73 Replies
- 30370 Views
Last post by quietcoolone
