Mystery noise
camper guy
Post by camper guy »
My 95 850T sedan has this metalic rattle when I drive over bumps or ripples in the road. My mechanic says it's the performance muffler. I have grabbed and shaken this thing and nothing. Any ideas? Short of riding on a creeper while my wife drives down the road so I can listen I'm lost.
1995 850 Turbo, IPD chip, 262 HP
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2857 times
Been thanked: 1332 times
Post by matthew1 »
Parking brake cable loose? It makes an annoying light metallic clinking sound.
Also -> Amazon link
camper guy
I'll check that thanks. Is there a way to adjust the parking brake?
matthew1
Site Admin
Post by matthew1 »
Take the plastic cover off the handbrake... just below it actually, between the front seats. You'll see a hex nut... tighten. But here's the catch: this is the cheesy, easy way to do it. If you tighten too much, your parking brake will 'drag' on the wheel, and it will get glowing, flaming, smoking hot after a few miles of driving.
You must decide if you want to try this method or do it right -- see Haynes manual for correct way. It involves taking the rear wheels off, adjusting parking brake from there.
I gambled by just giving it a few turns. But before all that, just go under your 850 and look for the cable and see if it's knocking around. It may not even be the culprit.
Also -> Amazon link
camper guy
I'll check to see if its loose underneath first. It makes sense because the parking break doesn't do squat to hold the car and the brake pads are less than 1/2 worn. They squeel anyway so I may have them replaced when I get a sticker next month since they have to take them off to lube them.
camper guy
I brought my car in for a sticker and told my Mechanic the noise was making me nuts. Turns out he found a torsion bar that was loose because the mounting bracket had broken away and had it welded. No more noise!
Of course, 4 tires, 4 wheel alignment and removal of the stuck draw bar in the hitch receiver for a short $615.00 later I was back on the road. Nice to have new tires though.
