About once a week, the power locks will not work for a few minutes. When this happens (whether parked or driving), the fuel gauge and trip information section goes dead. After a few minutes, all will work again.
Dealer says he can't fix it unless he duplicates the problem...hard to do.
Anyone know what the foor locks and fuel gauge have in common?
'01 V70 - Pwer Locks, Fuel Gauge
Just a quick look at the wiring but it is the C.E.M. that powers both of these systems (as it does almost all systems in the car) and it looks like relay 2/120 is common to these 2 systems. Try replacing this first as it is your lowest cost option.
It is a pity that Talbotg never let us know how things worked out.
I have the same model car with 120K. The fuel guage, trip information and power locking on the rear doors are permanently inoperative.
The front doors only will lock with the door buttons, but they will not unlock with the door buttons. The front doors will lock and unlock with the remote, but the rear three doors will neither lock nor unlock unless the function is performed manually.
2002V70,
If the literature is still available, I would love to take a look at it.
Volvo340,
In exactly what location were the network cables rubbing against the seat rails? Do the cables carry any identification?
2002V70,
Volvo340,
01 V70 T5 ASR. Same exact symptoms
- dead fuel gauge
- rear door don't lock
- front door can't unlock via driver door lock switch
- rear wiper + spray doesn't work
Wonder what other's did to fix...
- dead fuel gauge
Found the solution in this thread
http://forums.swedespeed.com/zerothread?id=69694
Lets see how long this lasts
If you want to reboot your car, make sure you read this the "ECC Temperature Fan" in the following page
http://www.freewebs.com/howardsvolvos/f ... #182389930
Dis/Reconnect battery requires the following sequence
- Wait 5+ min after key is out to make sure everything in the car is off
- Disconnect negative terminal
- Wait a few min to erase computer memory
- Insert key and switch to position II
- Reconnect negative terminal
- Turn the key to off
- Lock and unlock door (reset upper cabin electronics, without this step, your sunroof/homelink may not work)
Now set your clock
Now set your clock
- 6443 Views
Last post by 93Regina
- 611 Views
Last post by paul850
- 2848 Views
Last post by 98v70dad
- 1371 Views
Last post by CanadianRob
- 473 Views
Last post by kcwilliams
