We have a loss of cold a/c under accelation. It does not come back unless you turn the ignition off and then restart the car.
1996 Volvo 850 wagon non turbo with 197000 miles. We drive a lot of miles in western North Carolina and is a little frustrating in the summertime.
The a/c works fine as long as there isn't much heavy drain on the motor under acceleration.
Any help would be appreciated.
loss of a/c under acceleration, doesn't come back until v
lewismug
- Year and Model: 1999 S70
Have you checked the clutch plate gap with a feeler gauge? It should be between .020-.015. If the gap is larger than .020, then the clutch is worn. I have a quick/simple/cheap fix for this, so if it is worn, let me know.
'99 S70 270k miles--Stock
'00 Audi A4 Quattro 172k miles--Stock
- Has thanked: 17 times
- Been thanked: 35 times
Going off during turbo boost is normal, but it not coming back on isn't. Like others said, check your clutch gap...if that's not it you might have a faulty switch at your firewall.
