Computer "Disc" message
daharleyrdr
- Year and Model:
Sorry I believe this has been discussed before could'nt find it in search? On my 2000 V70XC Im getting the "Disc" message on the computer screen on the dash I believe it was said to switch the knob for the copmputer next to the reset button. This only works temporarily then it comes back? Any help? what does this mean? thanks Bill
- Has thanked: 17 times
- Been thanked: 35 times
It means "DISConnected" Your instrument cluster is not communicating with the ECU (main computer).
daharleyrdr
- Year and Model:
So Made In Japan in laymens terms what does it mean and can I fix it or I know this is a crazy question is it expensive actually these cars that is a crazy question I already know the answer but please enlighten me thanks Bill N
Well, I have seen it too but it usually goes away. The likelihood that your ECU has crapped out is pretty slim...I would think it's an electrical glitch. Unless you're real handy with taking the dash cover off and the instrument panel display out to clean connections I would let someone else (indy mechanic who's well versed with Volvo's or a dealer) deal with this one.
daharleyrdr
- Year and Model:
MIJ
Thanks your right Ill try to clear it like someone else told me to just turn the switch back and forth a few times that may clear it out or clean the contacts if not I have an Indy shop in NJ I use Ill see him if it continues to happen more often! Thanks again Bill
The DISC message you see in the trip computer display is indicative of the trip computer or INFO switch contacts being dirty or not making full contact. I had this issue when I had to desolder and reassemble the switch's circuit board to replace the lamp inside. In my case it was not making full contact.
You can operate the switch repeatedly to try to clean the contacts or replace the switch or even just live with the DISC message.
1998 Volvo S70 T5 Auto
1995 Volvo 850 GLT <- RIP
- 699 Views
Last post by BEJinFbk
- 2714 Views
Last post by okidiver
- 10551 Views
Last post by natural4reelz
- 11515 Views
Last post by precopster
- 723 Views
Last post by sjhowardmvs
