Hello
I am new here, my freind got a problem whit his 2.5 liter 850
When it is in dynoTest(or on rollers) it works more than okB but when it is going racing on the tracks it spurts out all the oil from the fillerhole!!
Both turbo and compressor mounted 1.7 bar pressure
I am from denmark, The engine bottom made in sweden by speciallist
Any sugusitions? Sorry for my bad english c;)
You can see the engine on http://www.hq-racing.dk
Best regards Gitcar
oil leaking 850 race engine
bockreiter
- Year and Model:
Try the balloon trick on the Dipstick tube. If the balloon does not inflate, you're friend may need just a new gasket on the Oil-filler cap. I've seen several reports of the gasket going bad. If the balloon does inflate, the PCV line may be clogged. I have a hunch though that the race track engine just simply overwhelms the filler cap gasket with oil spray on the inside which works it way through. Hope this helps!
'94 850 Turbo Wagon
approx. 200,000 miles.
Hello
Thanks for the reply, I dont belive the ballon trick wil give us the clue we are looking fore.
The cleerence on this engine (piston, cylinder ) Is a little bigger than an stock engine. A seperate tank i mounted for absorbing the oil coming out of the breather.
The gasket is brand new on the fillercap So!!
It simply emptyes the engine for oil in secons (not heltty for engine)
Result is conecting rod bearing defekt
this has happened 2 times now, but not when it is tested in dynotest
we have just returned from a race and got no clue at all
Gitcar Denmark
Gitcar Denmark
chuckcintron
- Year and Model:
So, you are saying that almost all of the engine oil is being poured out of the oil filler, with the cap on tight and a good gasket? I can't picture a situation that would create that kind of pressure/leak out of the filler.
You sure you don't have a cracked block that isn't showing itself until at the track?
-Chuck
-Chuck
1997 855GLT
bockreiter
- Year and Model:
Is the oil pump stock? What you're describing sounds like a great amount of oil is pumped into the head at a much greater rate than on a stock engine. What happens when the engine is idling or reving at relatively low rpm and you remove the filler cap? Any oil coming out then?
The main difference between the dyno test and driving on the track are vibrations. Is my guess correct that you run the engine at the same rpm on the dyno as on the track?
Do you have sufficient clearance between engine and hood to mount an extension on top of the head to increase the distance between valve cover and filler cap? If you can create enough room to place a baffle under the filler cap you might have a workable solution.
'94 850 Turbo Wagon
Free2drive!
- Year and Model: 2007 XC90
Hi
This is not much use but I looked at you link and it seems the motor is fitted for a rear wheel drive car. What have you made?
Matt
Matt
Hello
Thx for answers
We belive we have found a problem whit the radiator, it was modified but not quit right
The data loccer had a temp loocked at 1o5 celsius. So the piston rings might be dameged. Explaines why it empties the block
But we are not sure.
The oilreservoir is modified whit some plate welded vertikal, so the oilpump might have a problem getting oil fast enough
That explaines the dameged conecting rod berings
maybe
Bockreiter: good idea whit the raised fillercap, wil be in the back of our minds,and same rpm in dyno and on track
Chuck:We have a oilfume tank( is that spelled right?) mounted on the side
and our suspision is pointing at it now. (If you picture a coffeepot whit a hole in the side, and you blow in it. you can get it to spurt quit high)
Thats the best way i can describe what we think
Wil be back whit more info later
regards gitcar
Thx for answers
regards gitcar
chuckcintron
- Year and Model:
Understood.
It's hard for me to tell from the photos, but do I see a belt-driven oil pump? (in other words, is this a dry-sump configuration?) If so you may also need to play with the drive ratio, but I'm sure you know that already.
If it's not a dry sump, then you may want to move in that direction
Much easier to maintain negative crankcase pressure...
-Chuck
-Chuck
1997 855GLT
Hello
A Late Update
Now the engine is working as it should! Pistonring clearense and a little overheateing was the problem. It does 498Hp 700+nm. Tested last sunday(In heavy rain) But and it workwd
Best Regards Gitcar
- Has thanked: 17 times
- Been thanked: 35 times
I saw your 3 video's...the most impressive one is here:
So, you put the 850 engine in sideways and made a RWD 850, is this right?
- 44 Replies
- 5522 Views
Last post by ADent
- 489 Views
Last post by nickjggreen
- 2191 Views
Last post by chexny
- 753 Views
- 537 Views
Last post by BigJim
