Hi
1999 v70 2.5lit 10v 5speed automatic non turbo 265k miles (UK vehicle)
Keep getting fault code p0500 - vehicle speed sensor "A"
Anyone had this before ? or know where its located ? is it a big job to replace it if its faulty ?
The auto transmission changes up and down quite smooth considering how many miles its done and the engine is good
Seasider
vehicle speed sensor V70
- Has thanked: 17 times
- Been thanked: 35 times
I would think it's the same on mine as yours...rear most part of the transmission on the upper part, located closest to the driver's side...check the wires to it and connection and if they're good you may be in for a new one.
DoItMySelfGirl
- Year and Model: 2000 V70 SE
Is it possible for the connections to be loose. Is the vehicle speed sensor a part that intermittently brakes down or does it go all at once. Would I be driving around for 2mo with mostly good behaved car and here and there messing up. oh when the mileage goes to dashes in the speedometer does not register for some reason the brake light also was on with that collaboration ,I turn the car off wait a few minutes turn it back on and drive away fine. Is this indicative of a speed sensor crapping the bed or a loose connection
- FLXC90
- Year and Model: 98 V70 T5
- Has thanked: 16 times
- Been thanked: 45 times
that is indicative of a failing ABS moduleDoItMySelfGirl wrote: 13 Apr 2018, 13:43 Is it possible for the connections to be loose. Is the vehicle speed sensor a part that intermittently brakes down or does it go all at once. Would I be driving around for 2mo with mostly good behaved car and here and there messing up. oh when the mileage goes to dashes in the speedometer does not register for some reason the brake light also was on with that collaboration ,I turn the car off wait a few minutes turn it back on and drive away fine. Is this indicative of a speed sensor crapping the bed or a loose connection
Current Volvos:
- FLXC90
That would be the passenger side for the OPMadeInJapan wrote: 28 May 2008, 04:47 I would think it's the same on mine as yours...rear most part of the transmission on the upper part, located closest to the driver's side...check the wires to it and connection and if they're good you may be in for a new one.
Current Volvos:
- 39 Replies
- 9917 Views
Last post by Burn-E
- 1277 Views
Last post by Ozark Lee
- 460 Views
Last post by S60rColorShift
- 1739 Views
Last post by can
- 771 Views
Last post by E Showell
