Earlier today my 02 V70 started running almost like it wasn't firing on all cylinders. Even at idle, the engine is clearly loping. The car will drive but it lacks power. On any sort of incline it will struggle and the CEL will flash until I'm no longer calling for power at which time it extinguishes itself. I've been hearing some "muffler" noise that I arrtibuted to a heat shield. I'm now thinking maybe I have a plugged catalytic converter? Any other ideas?
Mike
2002 V70-XC, 120K miles, lacking power
JRL
- Year and Model: Several
- Been thanked: 16 times
ETM (under 10 yr/200K warranty) comes to mind
Bad converter couild be the other but you won't know until the codes are read
VCA
- Year and Model: 2008 S80 T6 AWD
- Been thanked: 5 times
Possibly. They may be misfire codes...some OBD-II systems momentarily illuminate the MIL to indicate a misfire. Otherwise, it could be that the ECU considers them 'intermittent' codes.MikeChick wrote:Thanks, does the fact that the CEL doesn't stay illuminated tell me anything?
2008 S80 T6 AWD
1999 S70 GLT
1999 S70 GLT
