I have changed the rear rotors and pads on my XC90, but now have a problem, how do you adjust the E brake as i cant see any adjustment cams on the back plates.
Thanks.
E brake adjustment. 2003 xc90
The adjuster on a 2005 model is not on the footpedal assembly - it is located driver's side bottom of the console and is accessed by removing the carpeted side cover.
Move the seat to it's rearmost position, pop out the heater discharge cover in the driver's side footwell (on transmission hump) and pull the carpeted panel off. The treaded adjuster is there. Put wrench on incoming cable sleave, outgoing sleave, and turn adjuster to create or remove slack.
If you don't have 3 hands, GENTLY hold the rearward cable sleave with a visegrip on the flatted section.
Worked for me !!
MAT
Worked for me !!
MAT
- billofdurham
- Year and Model: 855, 1995
- Been thanked: 5 times
Welcome to both of you to Matthew's Site.
Some of the XC90s have a parking/e/handbrake which is self adjusting and requires a different approach.
Bill.
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
Previously:
vegasjetskier
- Year and Model: 2010 Toyota Prius
- Been thanked: 6 times
This is for the S80, but might apply to your car since they use the same platform:
https://www.matthewsvolvosite.com/chat/p ... 0892#50892
- 6226 Views
Last post by RosserV70
- 27689 Views
Last post by OnTrack
- 366 Views
Last post by Bodhid
- 290 Views
- 948 Views
Last post by 1997volvo850
