I'm thinking about buying a 99 s70 for my son.with a blown motor. what engine years will fit in this car ? I think its a 2.4 non turbo
Thanks
Mike
engine exchange ,1999 s70
JRL
- Year and Model: Several
- Been thanked: 16 times
A 99 NON turbo motor
You will have some issues with others, MAYBE a 2000 NA engine will work, MAYBE, but that would be it.
Line up an engine first, that car is worth no more than $500 if everything else is OK (which you don't know because it won't run).
I assume a timing belt broke, so imagine the "good" care it got along the line.....NO SERVICING
Try www.erievovo.com for an engine, they're guaranteed
JRL
Head gasket
Cracked block!
Who knows, check it out.
A head gasket may cost as much as a used engine installed
Cracked block!
austinsusedcars
- Year and Model:
i have a 98 s70 volvo non turbo production date 11/97 can i put a 850 non turbo engin in it from a 95-96 [/img]
JRL
and this has what to do with this questionaustinsusedcars wrote:i have a 98 s70 volvo non turbo production date 11/97 can i put a 850 non turbo engin in it from a 95-96 [/img]
99s and newer are totally different, cannot go into a 98 and a 98 cannot go into a 99
dcovey
- Year and Model: 1998 S70 GLT5
You can put a brand new crate engine in it for only $6K. Of course you could buy a runner with about 100K miles on it for that price. If it's not a turbo, let it go for parts, you'll never get back what you put into it.
1998 S70 GLT5
16T, White Injectors, .040 Overbore, Masterlube pre-oiler, Teflon intake manifold spacer, VMS Performance ECU, VMS rods, ARP Studs, MSD Ignition, Reverse IC piping, completely new from the firewall forward.
- 5256 Views
Last post by RickHaleParker
- 1117 Views
- 752 Views
Last post by dm635
- 584 Views
- 17 Replies
- 4896 Views
