850 Volvo, Fan Blower Control Problem
My 1996 Volvo blower fan only works on the highest setting. All the fuses are good and I have replaced the resistory network in hopes of fixing this problem without luck. From physical inspection, the blower switch looks fine. It seems like it might be a ground problem but that would not explain the fact that the fan works on the highest setting. Anyone have a suggestion on what else I can check or replace?
- BEJinFbk
- Year and Model: '98 V70 R
- Has thanked: 94 times
- Been thanked: 146 times
There is a relay that selects either reduced voltage from the resistors for the lowerBGPKR wrote:Mine has a similar problem. The fan only works on high and when the switch is in any position. I had to pull the fuse to shut it off.
speeds or a direct 12 volt feed for the highest fan speed setting. I would look at that.
Sounds like the contacts may be fused. Should be easy to check.
Here is a link for diagrams:
http://volvo.techno.org.pl/wiring-diagrams.html
- Year and Model: Many Volvos
- Been thanked: 76 times
Both of the problems sound a lot like relay problems. Clay, have you checked fuse number 31? If that fuse goes bad the lower fan speeds won't work but speed #4 will work.
If BGPKR has a manual climate unit then the relay is for sure bad. If it is an electronic climate unit then the power stage has shorted out.
The max fan relay is on a small shelf in front of the main air duct. It can be accessed by removing the glove box. There are two relays on a manual unit one is the A/C relay and the other is the max fan relay.
- BEJinFbk
You'll find component locations in the wiring diagram manual.BGPKR wrote:Thanks. And where are these realys located?
It's a great book. They have Everything in there.
- Has thanked: 17 times
- Been thanked: 35 times
Try eBay....yours might be different than later model 850's so shop accordingly.
- 603 Views
Last post by BobbyC777
- 12 Replies
- 630 Views
Last post by JimBee
- 46 Replies
- 13066 Views
Last post by 93Regina
- 1881 Views
Last post by alschnertz
- 675 Views
Last post by thedancingfiddle
