83 760 w/ b28f v6 engine
it starts and idles but will not rev. 2800 RPM seems to be as high an rpm as i can get. New fuel pump, filter etc. What could it be? 96,000 miles
wojeepster
- Year and Model:
clogged cat? or does it die when you try to go over 2800 if so check throttle position sensor.
- billofdurham
- Year and Model: 855, 1995
- Been thanked: 5 times
It is too old for a TPS.
Which system is fitted, Continuous Injection System or LH-Jetronic?
Bill.
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
Previously:
- billofdurham
Which fuel pump did you replace and what is included in the 'etc'?New fuel pump, filter etc
Other things to check on the CIS are:
Throttle valves not opening properly.
Control pressure.
Mixture adjustment.
However, I am really curious about the pump.
Bill.
Previously:
Previously:
