I am in the process of changing the left drive axle and wheel bearing hub but I am literally stuck. the drive axle is seized in the hub and I cannot break it free. I tried squirting plenty of PB and banging the end of the axle with a hammer without success. does anyone have any suggestions?
Thanks for your help in advance.
drive axle seized in wheel hub
vegasjetskier
- Year and Model: 2010 Toyota Prius
- Been thanked: 6 times
Here's one man's method:
"Try putting some liquid wrench on there the night before. The kit has a new 36mm nuts, so what I do is take the old nut and screw it down so it's almost starting to show threads but not quite, and then with a large hammer I smack the nut until the axle breaks loose from the splines and starts to go in."
I think a bigger hammer is in order.
You dont want to hit the end of the axle without the nut on there because you can deform the axle and make it very difficult to remove. Also, put lots of anti-seize on the new axle so it doesn't get stuck too.
db130
- Year and Model: 2002 V70 T5
Heat up the hub with a handheld mapp gas torch in conjunction with the pb blaster soaking beforehand. The hub will expand due to the heat, enabling the PB Blaster to penetrate more effectively. THEN take the hammer to the nut as previously mentioned.
Alternatively, you could borrow/buy a cv axle puller: http://www.ipdusa.com/Volvo-S70V70-1998 ... -730-2540/
2002 V70 T5 169k
2002 V70 NA 249k
2006 Mini Cooper S 90k
2002 V70 NA 249k
- akitawagon
- Year and Model: 1997 855R
I had the same problem as you with the 36mm nut still stuck after soaking it in P'Blaster (like liquid wrench) for a few days and smacking the nut (not the axle) with the big hammer.
I didn't have a torch to heat it up (some of those small ones you can get at home depot are supposed to be good), so I ended up just using a 4-5 foot section of pipe slipped on my ratchet to give me better leverage to break the nut free.
If you have air tools it might easier, but the longer pipe definitely helps so that you can use your full weight on it as opposed to just your upper body strength.
1998 V70 T5 223K
1997 855R 215K
1997 855R 124K KIA... distracted driver on phone
1997 855 T5 141K KIA... water pump
1996 850 GLT 160K
1995 855 GTA 325K KIA... distracted driver on phone
1993 850 GLTS 201K KIA... t-boned
1997 855R 215K
1996 850 GLT 160K
ANIGAV Inc.
- Year and Model: 96 850 t5
thanks for this
1996 - 850 turbo
I had the same problem, thought I'd never get it off. Then I got a Front Hub Puller.
https://www.amazon.com/gp/product/B0002S ... B0002SRF6C
It came off like butter.
1998 V70 non-Turbo
Thanks everyone for your suggestions. I bought a wheel hub puller and got the axle free. It was fairly easy, but I did have to put a lot of elbow grease into it. Using a can of PB, hitting the end with the biggest hammer I could find, and using an impact hammer would just not free it, though.
Mine was corroded too and I ended up making a puller, just 1/2" plate with 5 holes to match the hub, and 12mm metric bolts. Worked great. Cost me $25 to have it made. Wonder if there is a market for these? Could be made much cheaper in quantity.
- 2473 Views
Last post by [email protected]
- 12 Replies
- 2125 Views
Last post by LOB
- 1963 Views
- 1908 Views
Last post by Mikaro07
- 1907 Views
