HI all,
My Hood does not open from the driver side but opens from the passenger side but that makes it hard to open the hood unless some one pulls while I pulls the latch.
Thank you in advance for any input.
Hood wont open form the driver side
shaimaa2000
- Year and Model:
Volvo S70 AWD Model 99 126K
- instarx
- Year and Model: XC70 T6 2011
- Has thanked: 1 time
Been discussed here many times. Adjust the cable slack at the lever inside the car and/or lower the driver side latch under the hood. Look in the Repair Database (tab at the top of this page) for detailed directions on adjusting cable slack.
I vote for lowering the latch a couple of millimeters first - it is easier, and adjusting the cable did nothing for me anyway.
2011 XC70 T6 - current
2017 Alfa Romeo Giulia Q2 - Totaled in 2022. Not my fault.
2011 XC60 - sold
2000 V70XC - given to a friend, wish I still had it.
2011 XC60 - sold
JRL
- Year and Model: Several
- Been thanked: 16 times
Lower the latch and for good measure put a rubber bumper on the rad support (to give more tension, so the hood will "pop" open (up)instarx wrote:Been discussed here many times. Adjust the cable slack at the lever inside the car and/or lower the driver side latch under the hood. Look in the Repair Database (tab at the top of this page) for detailed directions on adjusting cable slack.
Be careful and don't break the release cable! I did that and it is very hard to get the hood open again on the AWD.
1998 Volvo V70 AWD 165000-R muffler, HD endlinks, boost gauge
2008 Ford Fusion AWD 107000
2000 Ford Ranger 4wd 172000
1991 Toyota Camry 160000#1
Previous: 1982 Volvo DL (240) 160000
1998 Tacoma, Fords (6), Dodge, Montero,
GTO, Sunbeam Alpine, VW Dasher
I have the the same problem...but not really. I stuff a rag under the side that releases, near the hood latch, putting a little pressure on hood. Hit the release again and and presto! Your in! Lazy man's fix. Hey, I still drive
a Jeep! I'm just putting all that experience to work:)
Doug <///><
1999 Volvo V70 LT AWD X/C 143k back from the dead.
1995 Jeep Rangler Rio Grande 243k
1994 BMW 325i Sedan 226k
shaimaa2000
- Year and Model:
Would you please explain how to do that? I'm really having times opening my hoodholler1 wrote:Be careful and don't break the release cable! I did that and it is very hard to get the hood open again on the AWD.
Hi Shaimaa,
Hopefully this will work for you. When you release the hood and only one latch frees up, take a thick rag and stuff it on the released side of the hand release lever(under the grill by the bumper). This will put pressure on the unreleased latch, so when you pull the hood release inside the car again, the second latch releases and open like you would normally. Unless there is something else wrong, this generally works. The other fixes described in this thread work as well.
Doug <///><
- 2015 Views
Last post by dunamis
- 11 Replies
- 19477 Views
Last post by volvolugnut
- 13 Replies
- 2846 Views
Last post by jimmy57
- 779 Views
Last post by Vova585
- 12 Replies
- 2041 Views
Last post by dosbricks
