When I took my crank pulley off today there was no guide pin on the crank. Are these routinely left off? The timing belt has been changed 3 times, once by a dealer and twice by a very reputable shop.
And the problem is.....I apparently have the pulley on crooked because I can see the belts coming from the crank wobble. I know I have to get that straightened out, but should I have a guide pin in there or is it okay without it.
Also, is there a good way to hold the pulley to tighten the bolt without a special factory tool?
Thanks, Mark
240 B230 crank pulley
wojeepster
- Year and Model:
maybe the guide pin is stuck in the pulley and that is why you have a wobble. I just seem to remember a keyway.
- billofdurham
- Year and Model: 855, 1995
- Been thanked: 5 times
Is it possible you have dropped the key? I have done that before as they aren't always a tight fit.
Bill.
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
Previously:
I didn't drop it because I was being careful to look for it. And, the groove in the pulley was about 45 degrees away from the groove in the crank. So, it couldn't have been there. I will pick one up.
Bill, do you know of a good way of holding the pulley to tighten the bolt? I can set my compressor at 45-50 lbs and use an impact. Will that make it close enough or is there a better way?
Mark
Mark
1992 240 GL
1966 Sunbeam Tiger
1966 Sunbeam Tiger
- billofdurham
The way I was taught, by an old time mechanic, was to remove the starter and jam a screwdriver in one of the flywheel teeth. He had a screwdriver that was long enough to reach the floor but I had to find someone to hold mine in place.
Bill.
Bill.
Previously:
Previously:
Bill,
Thanks for the suggestion although I'm not sure if I'm brave enough to try it....something slips and I chip a tooth and I'm really in a mess. I'm going to see if the local Volvo shop has trick that they use that I'm brave enough to try:-)
Mark
Mark
1992 240 GL
1966 Sunbeam Tiger
1966 Sunbeam Tiger
- billofdurham
They will use a Crankshaft Holder, tool #5284, which fits on the pulley and fastens on to the belt tensioner stud.
Bill.
Bill.
Previously:
Previously:
Bill,
Thank you. Yes, I read about the tool...trying to find a substitute. I spoke to the shop today and now they have me confused. Is the "guide pin" built into the end of the crank shaft? That's what the shop made it sound like. They said it was piece that couldn't fall out. I was looking for a loose pin or key. I'm going to pull it apart tomorrow and I'd like to get it right.
Thanks,
Mark
Thanks,
Mark
1992 240 GL
1966 Sunbeam Tiger
1966 Sunbeam Tiger
- billofdurham
If you haven't already done so take a look at this:
http://www.swedishbricks.net/700900FAQ/ ... nsioner_PM
And for that tool:
http://www.swedishbricks.net/700900FAQ/ ... der%20Tool
Bill.
And for that tool:
Bill.
Previously:
Previously:
