Another 850 ECC question...
stanley_changuion
- Year and Model: 1998
Hi guys! Greetings from New Zealand!! I am the proud owner of a '94 850 Turbo! Teal Green with 229000km on the clock. I have one fault code on my ECC. 221- Pasanger damer motor position sensor open circuit or shorted to 12V. The question is: Where is the sensor? Is it inside the motor? I also suppose that pasanger side refers to Left hand drive vehicles, wich would be driver side over here? I removed the drivers side motor and all seems good. The shaft is ok. But my fan doesnt work at all? Will it work if the sensor is sorted out, or are there more problems? Only the one code, and it doesnt clear. Thanks. Stanley
stanley_changuion
Would anybody know if there are other model Volvo's that use the same damper motors? Maybe 960's? Thanks
VCA
- Year and Model: 2008 S80 T6 AWD
- Been thanked: 5 times
The ECC units are set up according to the driver's position, so it's left on LHD cars and right on RHD cars...your passenger motor would be the left side. The sensor is internal to the motor, if it is indeed a short to 12V, consider the motor unit dead. The damper motor itself, part number 9142629, can be found on '93-97 850s and '98-00 S/V/C70 vehicles.stanley_changuion wrote:Hi guys! Greetings from New Zealand!! I am the proud owner of a '94 850 Turbo! Teal Green with 229000km on the clock. I have one fault code on my ECC. 221- Pasanger damer motor position sensor open circuit or shorted to 12V. The question is: Where is the sensor? Is it inside the motor? I also suppose that pasanger side refers to Left hand drive vehicles, wich would be driver side over here? I removed the drivers side motor and all seems good. The shaft is ok. But my fan doesnt work at all? Will it work if the sensor is sorted out, or are there more problems? Only the one code, and it doesnt clear. Thanks. Stanley
2008 S80 T6 AWD
1999 S70 GLT
1999 S70 GLT
stanley_changuion
Awesome! Thanks for that mate! Does the fan stop working in a condition like that? Or do I have more problems? Allthough no other fault codes are present? Thanks again. Stan
- 1041 Views
Last post by xnRS
- 4982 Views
Last post by CRM
- 376 Views
Last post by AlanHMultiV70s
- 3419 Views
Last post by 98S70T5
- 34 Replies
- 4299 Views
