90 240dl overdrive switch
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
birk240
Post by birk240 »
I'm a little confused so here it goes: problems with shifting into overdrive
90% of the time. I traced down the relay and it checks out ok, the wiring for the switch seems to be ok and I have no idea to the location of the fuse
that is between the external o.d. on tranny and the shifter box. So with all of that, my main question is how do your remove the o.d. switch on the shifter. I have pushed and pulled with no luck?
billofdurham
Year and Model: 855, 1995
Been thanked: 5 times
Post by billofdurham »
The overdrive switch for the auto box has to be prised out of the shift lever. Use a small, flat bladed screwdriver - carefully. Disconnect the wires to remove it completely.
Fuse #11 in the main fuse box covers the heared rear window and 4th (overdrive) gear.
Have you checked the solenoid? They often cause trouble on these cars.
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
wahotsdad45
Year and Model: 240 1992
Post by wahotsdad45 »
A possibility is to do away with the OD and make it a four speed auto, IPD has a convert part that lets the trans do it's thing without the electric switch. It makes sense in alot of cases.
