Fuel Pump installation
meteg
Year and Model: 2007 V70 2.0T
Post by meteg »
Hello,
the fuel pump I have ordered has arrived but I have a problem with it.. the problem is I'm able to see one pipe connection port on the pump but I know Volvo 850 has two pipe connection ports am I wrong? the brand of the pump is TRE.. I bought it from E-bay so if there is anyone who knows about this pump or the pump I bougt please help..
thanks
Year and Model: Many Volvos
Been thanked: 76 times
Post by Ozark Lee »
I assume that bought the kit? It replaces the pump element inside of the OEM assembly. There are two lines on the assembly - one line is supply and the other is return.
meteg
Post by meteg »
Hello Lee,
the pump I have bought is not the OEM one. the brand is TRV it was stated on E-bay that its compatible with 850 but it feels like its not especially I cannot see the second pipe fitting.. if its not going to fit I will look for the bosch one..
thanks
Post by Ozark Lee »
The second line doesn't go to the pump element itself. What you are going to need to do is remove the OEM pump "assembly" - which does have two lines going to it - and then replace the pump itself inside of that "assembly". Hopefully they also sent a piece of fuel line, a couple of hose clamps, a wiring pigtail, and a new filter sock. I'm not familiar with that brand so I don't know what they send. If not clean up the sock the best you can and figure out a way to fit the new pump into the old "assembly".
The fuel pump output line only goes to the supply side line on the "assembly", the return line just basically dumps the unused gas from the fuel rail back into the gas tank.
I hope that makes sense. I think once you get the "assembly" out it will be apparent to you.
meteg
Post by meteg »
Hello again Lee,
now I'm confused more.. I dont understand why there isnt a second fitting on the pump.. I think I will give up doing this job because it might be becoming a real mess. it appears like I will have to buy the original pump later.
thanks for your comments and help..
JFO
Year and Model: '98 S70 GLT
Post by JFO »
This link to a post on VS will show you what Lee is describing and you can determine if you have all the parts.
http://volvospeed.com/vs_forum/index.ph ... opic=30882
Jim
'98 S70 Turbo GLT
280,000 km
Post by Ozark Lee »
As usual - pictures speak 1000 words. I knew I had seen a writeup somewhere.
Good find Jim.
meteg
Post by meteg »
Hello again,
many thanks for the pictures now I understand everything..
I will do it today..
meteg
Post by meteg »
Hello again,
I have been depressurizing the fuel system and removed the wiring harness of the pump and removed the pipes however I couldnt remove the retaining nut on the pump.. I know that a special tool is required for it but as usual I dont have it also is there another alternative method for removing the retaining nut on the pump housing? I have been looking in the repair database of the forum and a member named Luketrash has a post for how to remove the pump but I couldnt exactly see what he used to remove the nut on the pump housing..
any help will be appreciated..
Has thanked: 17 times
Been thanked: 35 times
Post by MadeInJapan »
If I recall correctly, it was an oil filter wrench, one that looks like a large set of pliars.
