Horn don't honk!
2001 S-40...horn does not honk if you press the lower portion of the pad. The upper right and left work, but not the bottom. Anyone have the 'how to remove and repair' pages of the manual? OR...could you just tell me how to do it? I have worked on my 850 and 740, so I have been inside before, just not sure of the details on this one.
- billofdurham
- Year and Model: 855, 1995
- Been thanked: 5 times
This is the VADIS instruction for getting into the steering wheel.
Disconnect the battery negative lead, having the radio code. Do no start work for at least 5 minutes after disconnection.
To remove the "Steering column panels" - remove 3 screws from the lower panel, lower the steering column to its lowest point and remove the upper panel.
Bill.
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
Previously:
- billofdurham
tkuper, welcome to Matthew's Volvo Site.
Which codes have been set? I can't find any associated with the horn not working.
Bill.
Bill.
Previously:
Previously:
- billofdurham
I don't know how that happened but the correct procedure for disconnecting the negative cable is:
Turn ignition key to position 0 and disconnect the cable.
To reconnect the negative cable:
Turn ignition key to position 11 and reconnect the cable.
The reconnect part often catches people out.
Bill.
Bill.
Previously:
Previously:
- Has thanked: 17 times
- Been thanked: 35 times
I split tkuper's last post because it was about an XC70. It is in the '01 and newer forum if someone looks for it.
- 4115 Views
Last post by MazdaDude
- 483 Views
Last post by 2forty
- 1282 Views
Last post by alex35saab
- 1368 Views
Last post by jimmy57
- 1900 Views
Last post by Paul-93-850
