My outside temperature gauge does not seem to be working as I would expect it to. It seems to creap up when the car is stopped or parked.
I seem to recall reading that there was some issue related to this but I'll be damned if I can find it.
Can anyone offer up some suggestions. Is this a known issue?
64,000 miles
Outside Temp Sensor 05 V50AWD T5
- billofdurham
- Year and Model: 855, 1995
- Been thanked: 5 times
I'm not sure if this is an issue with the V50 but my 850 shows a higher temp when stationary because of the location of the sensor.
This is from the V50 owner's manual:
Bill.At low speeds, or when the car is not moving, the temperature readings may be slightly higher than the actual ambient temperature.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
Previously:
redbrick
- Year and Model: 2005 V50 T5 AWD
Hm, mystery solved. I knew I read something about this somewhere. My other Vvos also tend to creap up when they are not moving but none of them as much as this one does........billofdurham wrote: This is from the V50 owner's manual:
Mike
94 - 940
97 - 850 T5
99 - V70 GLT
05 - V50 AWD T5
97 - 850 T5
99 - V70 GLT
05 - V50 AWD T5
