The first to occur, and only occurs occasionally is that sometimes I turn the key and nothing happens. Seems to occur more frequently when I have someone with me. So I thought of getting out, locking and unlocking the door. Does not help. If I leave and come back after about 30 minutes, it starts right up.
The second occurred randomly at first but is now constant. The right turn signal flashes faster on the dash and in the back but does not flash at all in the front. I checked the bulb and fuses, they seem to be fine.
The third is that the first setting on the windshield wiper, the intermittent, does not work anymore. This happened after the turn signal quick flash/front fail became constant.
Also, I have a rattle on the front right side, sounds like under the tire, when i go over rough pavement. I understand this could be a cv joint, tie rod, or strut. How do I determine which it is?
One final item - the glass in my driver side mirror is cracked. Can I replace the glass or do I have to replace the whole assembly?
My baby has over 100k miles and I am trying to find the most cost-effective way to make her happy again. Inspection coming up and I have been neglecting this for too long.
Thanks for any advice.
