Service Light reset
code-man850
- Year and Model: 855T '96
Can anyone tell me how to reset the "service" light? I know its schedualed to come on every 5,000 miles and i'm doing the required maint. I hate the light!
'96 855 Turbo
K&N, H&R, Mobile 1
Its a wagon thing...
You wouldn't understand.
K&N, H&R, Mobile 1
- Has thanked: 2861 times
- Been thanked: 1332 times
850 models 1996 and 1997: Dealer or one of the more expensive OBDII code readers will do it. Check for this feature before you buy one.
If you go to the dealer, call first and ask if they'll do the light as a courtesy (they did for me). Tell them you're coming in to buy a part from the parts desk, and you were wondering if they'd extend that courtesy to you.
While you're there, tell them to max out the interval... I believe it's 7500 miles and 18 months. The interval is programmable.
Other Volvo models: https://www.matthewsvolvosite.com/reset.php
[edited to add 850 '96/'97 vs. other models link]
SnookWhaler
- Year and Model:
What year and model is your car?
The earlier 850's 1993 to late 1995 can be reset under the hood using the diagnostic box.
There is a thread on here or Volvospeed that shows you how to use it. Really easy.
Edit:
Here is another link: http://www.volvoclub.org.uk/reset.shtml
Edit:
1994 Volvo 850 sedan 165K
code-man850
Dam that's why I love this site. Plenty of good knowlege.
'96 855 Turbo
K&N, H&R, Mobile 1
K&N, H&R, Mobile 1
code-man850
Of coars my 855 has to be a 1996.
'96 855 Turbo
K&N, H&R, Mobile 1
K&N, H&R, Mobile 1
SnookWhaler
- Year and Model:
Did you check for it here to see if you have the model before OBD II..
"1996 Model (Some of them)
On these models the diagnostic socket is in front of the gear stick. Switch the ignition on. As you look at the speedometer on the dash, beneath it opposite the trip reset button is a rubber plug. Remove the plug and with a thin pointer such as a ball point pen, depress the pin. This will reset the service light. "
Here is the link @ VolvoSpeed:
http://volvospeed.com/850slight.php
- akitawagon
- Year and Model: 1997 855R
The reset by pushing the pin (behind the rubber plug) on the dash display seems to be only available for 1995 and maybe some early '96 850 models that have the Yazaki instrument clusters.
If you have the other cluster, you might be able to check ebay for a Draper reset tool or something similar that will turn off the light.
Here are some discussion threads about it:
https://www.matthewsvolvosite.com/forums ... hp?t=10130
https://www.matthewsvolvosite.com/forums ... 01dee850ca
or you could just remove the bulb for the service light since you're doing your own work.
1998 V70 T5 223K
1997 855R 215K
1997 855R 124K KIA... distracted driver on phone
1997 855 T5 141K KIA... water pump
1996 850 GLT 160K
1995 855 GTA 325K KIA... distracted driver on phone
1993 850 GLTS 201K KIA... t-boned
1997 855R 215K
1996 850 GLT 160K
- 27 Replies
- 7684 Views
Last post by Blockpartie
- 13 Replies
- 6140 Views
Last post by esl_97_850_T5
- 1930 Views
Last post by precopster
- 41 Replies
- 9492 Views
Last post by slickdizzy
- 3948 Views
Last post by charleskennedy23
