Replaced battery and now the engine runs rough
brice24
Post by brice24 »
I just replaced the battery in my 1999 S70 and now when I start the car it idles very rough and will not rev. What gives?
Mike-Halewai
Post by Mike-Halewai »
Call me crazy, but I would simply try a different battery first of all. If that has no effect, then you may need to test and try a few other things.
Are you sure that you are using a large enough, or small enough battery, etc?
Mike.
94 850 Turbo Wagon.
BEJinFbk
Year and Model: '98 V70 R
Has thanked: 94 times
Been thanked: 146 times
Post by BEJinFbk »
What is the voltage measured at the battery?
Check when off, and also when running.
( Is this a new battery? Just Checkin'...)
895meztz94
Post by 895meztz94 »
When I replaced my battery I started having what I think are ETM problems.
1999 Volvo V70 2.4 Base 207k miles and counting
2003 Saab 9-5 Linear
waynej
Year and Model: 1999 S70
Post by waynej »
Did you have the key all the way off when disconnecting the battery? If not you can fry some expensive electronics. Did you clean the cable ends before connecting the new battery?
waynej
99 S70
96 854
87 245 wife's car
94 850 sons car
94 850 2nd sons car
Previous Volvos
93 850
87 744
85 244
82 244
80 244
78 244
78 245
76 265
71 P1800
71 142
bobsnow100
Post by bobsnow100 »
What are the condition of the battery cables and any other wires that connect at the battery. Make sure they are good . Sometimes the copper wires get white oxidation on them and you get bad contact. Check the ground wires also.
brice24
Post by brice24 »
OK. Battery good. I borrowed a OBDII scanner and found no codes except that the O2 sensor was not reading any voltage. I unpluged the O2 and now the engine will idle but not rev. What next?
Has thanked: 17 times
Been thanked: 35 times
Post by MadeInJapan »
Are you saying the wires to the 02 don't show voltage?
If so, you're going to have to fault trace those wires to where they connect in the engine bay and if that connection is corroded clean it, etc. I'm not sure what the voltage is suppose to be on those wires, but seems that Lee posted about this some time ago. If you're saying there is no voltage out of the 02 itself, I believe this is normal- it should show some resistence though, but minimal.
mom
Post by mom »
Everytime you disconnect the battery, the computer resets itself and it has to relearn your engine behavior particularly on idle because it is the reason of being of the throttle body. It will run smoother after a few hours.
S70 GLT 2000 Moondust
