exhaust manifold 1993 850 GLT
I have the same problem with my 1993 850. I am also having a problem with rough idle and periodic stalling at normal operating tempeture. I read the manual and it seems to be linked through oxygen sensor onthe manifold which reports back to the ECM (engine control module, which is the brain box ).
Are you having similiar problems with idle and stalling? I have found the manifold on line for around $350.00 US. I also checked Pick and Pull the salvage and a used exhaust manifold is $35.00 US. I think I'll try the $35.00 dollar option first.
Larryd
Larryd
studboltgkw
- Year and Model: 1993 Volvo 850 GLT
I know this is an old thread . . . wanted to add here for others with the same problem.
I had the same issue. I had a crack that ran all the way around the collector and seam that holds the exhaust sealing ring between the exhaust manifold and the catalytic convertor. I took the manifold to a welder and had the seam on the backside of the collector welded completely around. I re-installed the manifold . . . exhaust leak is gone.
