Fault codes on a 440 single point injection 1996
volvoskim
Post by volvoskim »
Finally got around to reading the codes on my sisters 44o si. 1.8 litre
The LED as returned 121 and 223.
121 I think is the air pressure sensor,223 the idle control valve.
Question is where is the air pressure sensor located? ,there is no unit on the intake elbow as with the multi point systems
Has thanked: 17 times
Been thanked: 35 times
Post by MadeInJapan »
I don't know a thing about your sister's car but looking it up on VADIS, it sure is nice looking! Do you have any pictures to share? VADIS (when switched to European models- I'm in the U.S.) shows an "intake load pressure sensor" on the throttle body. I'm assuming this is the same thing as an air pressure sensor. It is #2 in the diagram below:
Intake Pressure Load Sensor.jpg (23.64 KiB) Viewed 4921 times
volvoskim
Post by volvoskim »
Cheers for that,Ill have a quick look the nest time I bump into her.
I can take a few pics if you want.
billofdurham
Year and Model: 855, 1995
Been thanked: 5 times
Post by billofdurham »
1-2-1 is the Manifold Absolute Pressure (MAP) sensor, signal error.
Possible causes are wiring; vacuum hose split/blocked or the sensor itself.
To check the MAP sensor:
MAP sensor.jpg (68.47 KiB) Viewed 4661 times
2-2-3 on the single point injection is the Idle Speed Control (ISC) actuator, signal error/signal absent.
Possible causes are wiring short or open circuit.
To check the ISC actuator:
ISC actuator.jpg (75.81 KiB) Viewed 4648 times
MIJ - lots of 440 pictures at:
http://www.volvogallery.org.uk/showgallery.php?cat=3191
They were popular cars over here and there are still many of them on the road. My neighbour has a '95 1.9 turbo diesel in immaculate condition which can still return 53mpg on a motorway run at 70mph. (That is the legal speed limit and I think he is frightened to say that he is usually in excess of this.)
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
Thank you Bill...nice looking sporty but small Volvo...wish we had it here.
volvoskim
Post by volvoskim »
Hi thanks for getting back.
Is the map sensor located on the bulkhead?
billofdurham
Yes.
This shows the locations of the engine management sensors and other parts on that car:
Sensor locations.jpg (144.91 KiB) Viewed 4684 times
Bill.
Previously:
volvoskim
Post by volvoskim »
Excellent,thanks for your help
Ian
volvoskim
Post by volvoskim »
I went ahead and replaced the MAP sensor,rather than checking it.
Anyway Im now getting code 112, or ecu problems, but the car as a lot more power.......puzzled!
billofdurham
If you have more power then the MAP sensor was probably iffy.
Check the Engine Control relay and the ECM:
EC relay.jpg (26.31 KiB) Viewed 4647 times
Bill.
Previously:
