Did you know? 🤔
Fault codes on a 440 single point injection 1996
Discussion and advice for 440, 460, 480 owners.
1986 - 1997 440
1986 - 1997 460
1986 - 1997 480
volvoskim
Year and Model:
Has thanked: 0
Been thanked: 0
volvoskim
Post by volvoskim » Mon Dec 08, 2008 11:36 am
Finally got around to reading the codes on my sisters 44o si. 1.8 litre
The LED as returned 121 and 223.
121 I think is the air pressure sensor,223 the idle control valve.
Question is where is the air pressure sensor located? ,there is no unit on the intake elbow as with the multi point systems
MadeInJapan
Has thanked: 7 times
Been thanked: 25 times
United States of America
MadeInJapan
Re: Fault codes on a 440 single point injection 1996
Post by MadeInJapan » Mon Dec 08, 2008 5:09 pm
I don't know a thing about your sister's car but looking it up on VADIS, it sure is nice looking! Do you have any pictures to share? VADIS (when switched to European models- I'm in the U.S.) shows an "intake load pressure sensor" on the throttle body. I'm assuming this is the same thing as an air pressure sensor. It is #2 in the diagram below:
Intake Pressure Load Sensor.jpg (23.64 KiB) Viewed 2770 times
volvoskim
Year and Model:
Has thanked: 0
Been thanked: 0
volvoskim
Post by volvoskim » Tue Dec 09, 2008 1:09 pm
Cheers for that,Ill have a quick look the nest time I bump into her.
I can take a few pics if you want.
billofdurham
Year and Model: 855, 1995
Has thanked: 0
Been thanked: 3 times
billofdurham
Post by billofdurham » Wed Dec 10, 2008 3:45 pm
1-2-1 is the Manifold Absolute Pressure (MAP) sensor, signal error.
Possible causes are wiring; vacuum hose split/blocked or the sensor itself.
To check the MAP sensor:
MAP sensor.jpg (68.47 KiB) Viewed 2510 times
2-2-3 on the single point injection is the Idle Speed Control (ISC) actuator, signal error/signal absent.
Possible causes are wiring short or open circuit.
To check the ISC actuator:
ISC actuator.jpg (75.81 KiB) Viewed 2497 times
MIJ - lots of 440 pictures at:
http://www.volvogallery.org.uk/showgallery.php?cat=3191
They were popular cars over here and there are still many of them on the road. My neighbour has a '95 1.9 turbo diesel in immaculate condition which can still return 53mpg on a motorway run at 70mph. (That is the legal speed limit and I think he is frightened to say that he is usually in excess of this.)
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
MadeInJapan
MadeInJapan
Post by MadeInJapan » Wed Dec 10, 2008 7:48 pm
Thank you Bill...nice looking sporty but small Volvo...wish we had it here.
volvoskim
Year and Model:
Has thanked: 0
Been thanked: 0
volvoskim
Post by volvoskim » Thu Dec 11, 2008 10:47 am
Hi thanks for getting back.
Is the map sensor located on the bulkhead?
billofdurham
Has thanked: 0
billofdurham
Post by billofdurham » Thu Dec 11, 2008 11:25 am
Yes.
This shows the locations of the engine management sensors and other parts on that car:
Sensor locations.jpg (144.91 KiB) Viewed 2533 times
Bill.
Previously:
volvoskim
Year and Model:
Has thanked: 0
Been thanked: 0
volvoskim
Post by volvoskim » Thu Dec 11, 2008 11:54 am
Excellent,thanks for your help
Ian
volvoskim
Year and Model:
Has thanked: 0
Been thanked: 0
volvoskim
Post by volvoskim » Wed Dec 17, 2008 2:18 pm
I went ahead and replaced the MAP sensor,rather than checking it.
Anyway Im now getting code 112, or ecu problems, but the car as a lot more power.......puzzled!
billofdurham
Has thanked: 0
billofdurham
Post by billofdurham » Fri Dec 19, 2008 12:14 pm
If you have more power then the MAP sensor was probably iffy.
Check the Engine Control relay and the ECM:
EC relay.jpg (26.31 KiB) Viewed 2496 times
Bill.
Previously:
