Remote fob question
Craig
Post by Craig »
Can anybody tell me which design of remote fob I'm supposed to have for a 1996 T5 gle? I Know there are two but dont know which one.
The one I have is slim and has two buttons one below the other, not the square one with two small buttons side by side.
If I had the wrong remote, would this explain why my remote works but only if its held right up against the glass break sensor?. :?
potroast
Post by potroast »
sounds like a dead battery. If you had the wrong remote, it wouldn't work, at all.
Craig
Post by Craig »
Na its not the battery, I have tried to code a brand new fob in the past and got exactly the same result... I dont know if its a fault in the alarm somewhere or if I have the wrong fob. :cry:
Lomax©
Post by Lomax© »
The relay is rather large .. maybe it just needs to be re-seated ..and the fob reprogrammed..
1979 242 DL Black on Tan 54K mi (Rebuilt)
1995 854 N/A Black on Tan 137K mi (Orig)
potroast
Post by potroast »
Craig wrote:If I had the wrong remote, would this explain why my remote works but only if its held right up against the glass break sensor?. :?
If the remote works, even if only at extremely close range, then you have the correct remote, and it is properly programmed. This sounds like a receiver problem, since you claim the battery is good.
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2857 times
Been thanked: 1332 times
Post by matthew1 »
The remotes were not engineered well. I've read of many that just get worse over their lifetime. Mine is this way. Unless I press the unlock button *very* quickly, it acts as though I pressed Lock. Batteries new/old doesn't matter much. Range is max 20 feet.
I have the big button over little button.
Also -> Amazon link
