Brake Light Replace
I have a 2001 V70 XC wagon. My passenger side upper brake light assembly is damaged where the light snaps into the lens assembly (from excess heat, I think). I will need to replace the lens assembly, but I don’t see how to remove the old one. Does anyone have specific instructions? A diagram would be helpful also. Does it mount with screws, or clips which allow the light to snap off? The only access to the back side appears to be by removing the rear speaker, but even after doing that I cannot see very much. Thanks for any suggestions.
- Has thanked: 17 times
- Been thanked: 35 times
You might find one cheaper on eBay than an on-line place. Shop around. I hope the following helps you:
If you need links to the other operations that you have to go through frist, let me know (loud speaker grille, etc.)
Thanks for the helpful PDF, Madein. Is this document available to the average Joe, or is it from a subscription site? I am uncertain about the removal of the side panel cover, cargo compartment side panel and the cantrail panel.
These diagrams are from VADIS...a 2 DVD set you can buy from eBay. Here are some of the other parts to your process (you might not need all of them) that might be helpful to you:
No...one of the pdf files should have the process. Reach in, twist the cover and pullout... no outer lens is ever touched.
- 1040 Views
Last post by volvooh
- 14 Replies
- 5178 Views
Last post by coded9
- 1483 Views
Last post by T64me
- 13 Replies
- 5321 Views
Last post by S40volvo2007
- 254 Views
Last post by Wackneck
