leaky 960 sunroof
beertownbmw
Post by beertownbmw »
trying to fix a leaky sunroof on 96- sedan. Any advice????
thanks
John
[/b]
beertownbmw
Well beat you all to it. I found the root cause of most leaky sunroof problems on this car is clogged drain holes. In the both front corners of your sunroof, between headliner and roof, there is a drain hole. This drain goes down your front posts and meets your windshield base drain. This hole, on both corners. clogs and water spills over, down along your headliner ect.
Use high pressure air and blow these holes out. Test by pouring water into the area. The water should flow down, and out just behind your front tires.
John waldron
859-986-6985
